Feature supression in drawings
Is it possible to supress features on a part for or in one specific drawing?
For example: Think of a two piece mold that you want to make separate drawings for. First the plain blocks with screw holes so they can be bolted together, then a "assembly" drawing with the cavity.
Obviously if you supress in the model, it effects all drawings. Is there a way around this?
Thanks.
Scott
Thanks.
Scott
RE: Feature supression in drawings
http:
http://www.eng-tips.com/threadforum.cfm?lev3=70
