installing a 24 vdc power supply on 12v van
I am working on a project and i need your ideas/ help
on a 12 volt van, i have some equipments which they need to be powered by 24 vdc (about 30A) in the same time i should have a two 12vdc batteries in series to generate the 24 v as a powerpack in case of turning off the engine!
I had installed a 12 - 24 vdc converter in which it is operated by the car bettery.
is there any possible way to make the equipments to turn on (smootly)to the external powerpack in case of turning the engine off?
is it possible to charge the external batteries from the car alternator?
thanking you!
thanking you!
RE: installing a 24 vdc power supply on 12v van
Why not add a 24V independent system to do only those things that need 24V. I think you could charge two 12V batteries by using a charging circuit hooked in parallel to the batteries - not sure about how you go about doing that if they are already hooked in series for load use.
Good Luck
Mike Halloran
Pembroke Pines, FL, USA
Google Niehoff and see what they have to offer. They aren't the only ones who make such equipment, just the only ones I can get to pop into my mind right now.
rmw
