saving drawing without references
Hi all
I seem to have a problem.
How do I create a drawing thats not directly linked/reference to the part that it comes from.
In other words, when I create a drawing, and then modify the part, the drawing updates. How do I stop this. I just need the drawing without modifications.
RE: saving drawing without references
http://hel
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
corblimey,
It works when I save as a DXF, but is their anyway to save it as a slddrw?
You can make a non-slddrw file as CBL has suggested. But if you want a slddrw file linked to a part then by default it will reflect changes to the part.
There are many suggestions that can be offered, but they would be better targeted if we knew the what and why you want to do this. Please explain.
- - -Updraft
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
The drawing will not be able to find the model. SW will prompt you to find it, if it thinks the model needs loaded.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
One of the points of having 3D solid modeling is that the drawing and model is associated, or parametric.
IMO, to break them, might as well use ACAD...or a cheaper CAD.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
Michael
