Ansys Extract Time (Load Factor)
I am currently trying to run a non linear analysis with a monte carlo analysis, which i am confident is working as it should.
But, I am missing a single random output variable in my monte carlo analysis. If someone could please help me with respect to the commands that i should use, to extract the final load factor (time) for the structure, so that it appears as a random output variable for every permuation that set the monte carlo analysis to run, but also if you could help me understand how to extract the final load factor (time) into excel for each of the permutations.
It does not just have to be the final load factor, it could extract all the time (load factors) but as long as i can see the ultimate load factor which EACH frame permutation is able to reach.
I am attaching the script for your assisstance in understanding what I am trying to achieve.
Thank you
Thank you
