How do I move a sketch that has been extruded in Solidworks 2010?
Hi.
I have a solidworks 2010 file with a main body of a coffee press and the handle.
I need to move the handle so that it is in line with the rest of the coffee press body (Glass Caraf).
I also need to move anothe part, that looks like a screw bit, to inserct a cylinder so that I can do a Surface Cut.
The screwbit part only moves up and down, and not right to left, and ofcourse I need it to go left. However, I can't figure out how to move these parts.
RE: How do I move a sketch that has been extruded in Solidworks 2010?
Is this coffee press part of an Alaskan venture?
I don't see the body, only the handle. My program is asking for MasterForm.sldprt.
Sounds like something that happened to me. I had to change a boss that was extruded up to a point on a sketch. I had to add a new point to the sketch and make the sketch visible to change what the boss extruded to.
