Hardy Cross Method
Hardy Cross Method
Hardy Cross Method
I have created a simple EXCEL tool that uses Hardy cross method to  calculate the water flow  through each pipe in a single loop that consists 6 pipes. The loop is fed by 9 well pumps. I use the solver tool in EXCEL to do the iteration.  Although solver gives me the soltions, still the Delta Q(Assumed flow- Actual flow) in the loop is fairly large. Any thoughts on this?
RE: Hardy Cross Method
sounds like a lot of work. why not try epanet for free?
You may have reached a point where you have one or more (even all) pipes changing their flow direction and yet the absolute value of dQ remains numerically constant, ie. flows are alternating from +Q to -Q during each iteration.
"I am sure it can be done. I've seen it on the internet."  BigInch's favorite client.
"Being GREEN isn't easy." Kermitfrog http://www.youtube.com/watch?v=hpiIWMWWVco
http://virtualpipeline.spaces.live.com
cvg,
But what about the gain of knowledge and technical  challenge!
Good luck,
Latexman
Thanks  guys for all your feedback. Yes I can use EPAnet, watergems or infowater. But I am going to develop this tool for  a well field analysis and the loop is the first subcomponent.
