enercalc column question
Why does enercalc say for non sway columns only on the slenderness tab? I am trying to use the program to analyze a masonry column with fixed base and free top subject to a lateral loading at the top.
RE: enercalc column question
Maybe you should double the length and load it at midspan.  Alternatively, maybe you should design it by hand.
BA
