Repair procedure
Repair procedure
I am looking for procedure for repair the inside corroded surface of POSITIVE CHOKE VALVE that the material is indicated CA-15 ( martensitice stainless steel casting alloy ) . the size of valve is 4 1/16" and suitable for SOUR GAS is essential requirement.
Refer to my searching the ER410 or ER410NiMo filler metal with PWHT can use for welding/repairing.
> What is your suggestion or experience about filler ,welding process and machin and relative procedure?
> Is the ASTM A488 applicable?
G.R.H
Technical Inspection Department
G.R.H
RE: Repair procedure
ER410NiMo is reasonable for this weld repair. No issues.
Yes, A 488 should apply.
JB
Petrotrim Services
