Non-Associative Body After Mirroring
How do you mirror a body without having an associative copy. In other words, is it possible to obtain two separate bodies so that you can edit the copied body without altering the original.
RE: Non-Associative Body After Mirroring
1st solution if you need 2 different parts:
file save as
associative copy
then you can edit the original features
2nd solution if you need 2 solids in the same part:
Assuming that your first feature is based on a datum csys
create a new datum csys
copy your first feature
then paste it on the new datum csys
associative mirror copy the new solid
then you can edit the pasted features
Didier
Edit > feature > remove parameters > select mirrored body
The mirrored body will become an "unparametized feature"
