30 kHz / 3 Phase signal
Hi, I'm trying to generate 3 x 30kHz signal each phase seperated by 120 degrees. These 3 phase will be used to turn On/Off FETs that will power some high frequency transformers.
What I'm looking for is the lowest cost effective solution to generate the signals. I was thinking of using 3 Op-Amps but I'm a bit worried about the reliability/accuracy for a production product. I'm sure there are plenny of cheap PWM ICs that could do this more effectively, I just don't know them.
Here are my specs:
3 phase 30 kHz signals, seperated by 120 degrees
Accuracy of ±5%
Supply voltage 10V
Waveform: Square, Triangle or Sin, I just want the reference
Power Output: Very small as it will trigger FETs.
Anybody had anything to suggest?
Here are my specs:
Accuracy of ±5%
Supply voltage 10V
RE: 30 kHz / 3 Phase signal
Will post more recent efforts soon, but there are
some old reference drawings at:
htt
<als>
Some gates need lots of charge and that translates into a high load if you run at 30 kHz. It depends on your FETs.
Gunnar Englund
www.gke.org
Glenn
How about a low end PIC microcontroller ?
One chip, low cost and simple.
And you could do neat things, like building in dead time.
However, I do agree that if you need things like deadtime, using an MCU would give much more flexibility.
Glenn
Ph3 Ph2 Ph1
1 0 1
0 0 1
0 1 1
0 1 0
1 1 0
1 0 0
A uC would have been neat too but since it's a volume item I would have had to make a mask on the IC... which I try to avoid.
Anybody has recommendations on a cheap CMOS gate that could do the job?
BeerBaron
A best way to build a state machine is to use either an EPROM or a programmable logic array chip, (or use a microcontroller). All of which will require individual programming.
Glenn
http://www.altera.com/
TTL counter is the simplest way to go. Or just do PLD if you know how to program.
Yes, "dead" time is very important.
From TTL to 10V FET gate - use any low side FET driver from IXYS or Micrel. Do not use IXYS "4 series"!!!!
They have "5" now - improved.
Depending how big is your FET - need to use "big" gate driver.
For 30kHz and average 50A FET - 2 A driver should be OK.
"dead time" - start in 100nS-200ns range.
If you don't know what "dead time" is - Google.
"dead time" can be easy done with 1R, 1C, and diode.
This whole design is kind of strange- you will be driving 3 phase SQUARE(???) signals into one transformer? Or few transformers?
Are you sure you don't need 3 sine signals 120deg shifted? then PWM them with some higher frequency?
Saturated switching of the driver is also going to be a lot more efficient than some kind of linear power amplifier.
