Fixed Displacement in positive/negative direction
I want to fix a face (simulating a support) in a specified direction. The support is free to move in the +ve x and y direction, but not free to move in the -ve x and y direction. The support is also fixed in the z direction.
See attached image....
In ANSYS i can only see how to fix a displacement (by setting it to zero) in both the positive and negative directions at the same time.
Is there a way of doing this? Using springs perhaps?
Thanks.
Thanks.
RE: Fixed Displacement in positive/negative direction
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
I have put a spring on the in the x and y direction and that spring acts longitudinally - therefore if i then apply a force to the opposite side, the sping will compress by the same amount it will extend. So this isnt really doing much better than having a fixed displacement!!
