Underwater concrete repair of slab
I have a boat ramp that extends underwater. The last section, 2' under the waterline, is broken up and needs to be replaced. Anyone have any experience pouring concrete under 2' of water? (The area in need of repair is about 2' x 3') Is this possible, and if so, any tips (mix additives, process, etc.) you could relay would be great!!
Thanks...
Thanks...
RE: Underwater concrete repair of slab
"Here is a somewhat dated article (1962) that describes the traditional way for placing concrete underwater with a what is called a tremie:"
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
Thanks for the feedback...I think based on the size of the hole, I'll try pouring through a pipe. As far as the top goes, maybe a weighted down sheet of plywood over the pour will give me a reasonable surface (at least good enough for trailer tires).
The tremie article was helpful.
Intrusion Prepakt /marineconcrete.com
