Tightening sequence for 42 bolts
Does anyone know of a tightening sequence for a 42-bolt-hole flange? It's for closing up a 30" manway on an aboveground storage tank (atmospheric). I've been able to find them for flanges with 40 or 44 bolt holes, but nothing else. If there aren't any that exist, does anyone know of the method for finding a proper sequence? The sequence I came up with is just tightening every 12th bolt (with an occasional offset thrown in, obviously).
Thanks!
Thanks!
RE: Tightening sequence for 42 bolts
You can follow the "star" method sequence for the 42 as well.
If you worried about the fact that 42 can not be divided exactly by 4, I don't think it is a problem.
Also look at the latest PCC-2, the 2010 eddition has some interesting alternative bolt up procedures.
Just my two cents worth.
A question properly stated is a problem half solved.
Always remember, free advice is worth exactly what you pay for it!
http://www.ap-dynamics.ab.ca/
