Calculating Max discharge pressure of Liq. Ring Compressor
Does any one know of any theoretical equation for calculating the max possible discharge pressure or compression ratio of a liquid ring compressor?
Since LRs are positive displacement machines, when does the pressure increase stop?
Any references would be great!
RE: Calculating Max discharge pressure of Liq. Ring Compressor
Positive displacements usually take you to when the rod breaks, the top blows off, a seal blows out, you melt down, or ... you run out of power to squeeze it any smaller.
Other than that see what you can here,
http://www.eng-tips.com/viewthread.cfm?qid=93865&page=15
Noting that if its a vacuum appliation there are vapor pressure constraints,
http://en.wikipedia.org/wiki/Liquid_ring_pump
"I am sure it can be done. I've seen it on the internet."  BigInch's favorite client.
"Being GREEN isn't easy." Kermitfrog http://www.youtube.com/watch?v=hpiIWMWWVco
http://virtualpipeline.spaces.live.com
