Want to buy OD/ID Grinder
I have the task to buy used OD/Id grinder, any help is going to be appreciated, has to be for 8'' diameter part and length about 14''. Thanks for any help.
RE: Want to buy OD/ID Grinder
Checkout anyone of the many surplus equipment sites as they are hooked together like the Auto salvage yard's.  The availability of machines will depend on the accuracy and metal removal you require for your work.
Here is just one of the many extra machinery providers. If possible I would go and take a look at any equipment you anticipate purchasing.
http://www.surplusrecord.com/srg/009210.htm
