Is it possible to convert from sound power to sound pressure level?
Hello All,
Due to some ignorance on the part of our sales department we ended up with a contract which referanced a maximum Sound Power Level of XX DBa. The exuipment manufacturer is garunteeing Sound pressure level.
I have been tasked with converting between the two, but I have very little to go on and all my research on the topic has so far come up empty.
1) Is it possible to convert from sound power level to sound pressure level?
2) If possible how do I go about doing so? Is there a standard covering this? Perhaps a discription in a book?
Any help on this matter would be greatly appreciated.
A question properly stated is a problem half solved.
Always remember, free advice is worth exactly what you pay for it!
http://www.ap-dynamics.ab.ca/
RE: Is it possible to convert from sound power to sound pressure level?
You need to make/determine a few parameters.
1) Distance to the sound pressure level point, (usually 3 feet or 1 metre).
2) Is the measurement point indoors or outdoors. Most contracts just assume outdoor conditions or "free field conditions". i.e. Q=2.
If the source is indoors and your guaranteed pressure level is indoors, then you will need complete room acoustics information which is covered in a typical acoustics book.
3) Or you can do a very simple estimate/conversion by subtracting 12 dB from the sound power level to get a ballpark sound pressure level (free field assumed).
4) One last thing to note is that the conversion is frequency dependant so the best conversion is done with octave or third octave band levels. This is not very significant if the distance is short such as 3 feet but can be very significant if the distance starts to approach two or three hundred feet or more.
I don't know the specifics of your contract but if your guarantee is 90 dBA power level and the equipment supplier has guaranteed 90 dBA pressure level, you have a much tighter limit to meet. (90 dBA power level in free field is about 80 dBA pressure level).
Thanks for your responce.
1) I believe distance is 3 ft
2) The unit is an outdoor unit installed as part of a package.
3) That simple conversion leads to the conclusion that were screwed..... oh well, cest la vie.
4) I will keep that in mind as this ugly topic is broached with the customer.
Is there a national standard or industry accepted method you could point me towards for performing a formal calculation myself. The old "some dude on the internet said so" responce won't be good enough on this one.
h
One significant issue to calculate sound power form sound pressure or vice-versa is the size of the source. 3-ft distance from a gas turbine enclosure is quite different than 3-ft from a small residential AC condensing unit. The area factor must be addressed.
Walt
Cheers
Greg Locock
Lp = Lw - 20 log (r) + DI -11
Lp = sound pressure level.
Lw = sound power level
r = distance from source to receiver
DI = directivity index. Use 3 for free field (outdoors).
The above book is an excellent book.
http://www.bksv.com/Library/Primers.aspx
Ted
Look into page 12 of ISO 3744 wherein you can refer teh same to your customer
Jeyaselvan
