Changing properties of .slddrw files
Hi!
Is there a way to edit the properties of a bunch of drawing files at the same time.
I would like to be able to take all the drawing files from a folder and be able to edit their properties in a window (think excel type).
Is it possible?
Patrick
RE: Changing properties of .slddrw files
Patrick if you can explain what editing you looking to do in the drawings, someone on the forum may help you with a quick macro.
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
Thanks guys!
I tried a couple of macros from the FAQ Corblimeylimey suggested and I should be able to accomplish what I'm looking for.
Essentially what I want to do is to take let's say 10 .slddrw files and insert the project number in the custom properties in a simple copy and paste motion without opening each files independantly.
Cheers
Patrick
