Dual Mech seal for styrene monoper application
Dear All, I would like to hear from someone who has experienced leakage problems with dual mech seal that is designed for pumping styrene monomer.we are having seal reliability issues as the seal fails very frequently say 2 times a year due to various reasons such as i/b bellow tear during start up due to polymerization and subsequent sticking of sealing faces prior to start up, o/b coking and etc...we were able to eliminate the O/B coking issue,,...but i/b polymerization has been unresolved yet...can anybody share their knowledge as how u avoid the polymerization and what seal is being used in your plant? the pumping is being switched every two weeks in order to avoid long stand by period...do anybody actually use a pusher seal...i'm interested to know coz i would like to eliminate the bellow design which i feel is not robust enough...the pumping temp is 35 deg c...barrier fliud is EB...having a 10 lit bladder and air fin cooler....BF temp is around 40 to 50 deg c...
Thanks in advance... Please dont hesitate to ask me should u need more details...
RE: Dual Mech seal for styrene monoper application
Thanks for reply. The bellow does not clog up but it shear off as the faces stick together.
As per operation, it is best to keep the temperature below 40 to avoid polymerization. O/B coking mainly caused by high pressure(15bar) temperature as the seal system(53B) uses air fin cooler. EB= ethyl benzene....ethyl benzene reduces the tendency of polymerizaton. the mistake we did is that we removed plan and now are reinstalling the plan11 piping. The seal system is 53 B and it is filled manually and directly from the header.
Now we decided to install pusher seal with perfluro elastomer as secondary seals and introducing plan 14 to have better circulation around the I/B seal.
Trust it will solve the problem....please provide if u have better solution.
