NX6 part families
NX6 part families
I have a series of varying diameter spring dowels and for each diameter there are different lengths; if I had one part number for every dia/length variant there would be close to 160 parts.
I don't know if this is possible but I'd like to create a part family that uses user prompts ie. The user picks the dia from the family attributes hits OK and then, in some way, is prompted to give the dowel a length.
If it is possible it would reduce the part numbers to 9.
My first post & any help appreciated(even if only to be told it's not possible - at least then I can move on)
RE: NX6 part families
Give it a try.
Best regards,
Michäël.
My concern with deformable parts is that the diameter & length could then be given arbitrary sizes that are not within a standard range and as the dowel should be in our Standard Parts library I'm not sure that would be acceptable.
I would also have to add 'material thickness' which I can currently control via the part family spreadsheet.
If working with TC you can add a database attribute to the table.
First two columns of the spreadsheet are the family members name but you can add also database atrribute like description as a column in the spreadsheet. Can use it like
length x diameter x thickness, so if you look for the parts you have all the info presented in the file open menu.
Best regards,
Michäël.
Best regards,
Michäël.
It gives precise control over your parts.
How do you stock the parts in the store room for assembly? Does each diameter/length have a unique part number? Use the system in the same way so your BOM can be used to pull parts for assembly.
Ben Loosli
There are over 300 variants (having now been asked to provide both light & heavy duty) and I was hoping for an easier way of setting up this amount of parts.
This was to save time in creation and we also 'Publish' parts, via Teamcenter, to multiple company sites and large part families have been difficult to deal with.
Thanks for the advice, I'm beginning to realise there seems no other way but to put them all in a part family spreadsheet - perhaps one family per dia.
You need to look at which ones may need to be substituted when setting up the families. If you only replace a pin with a shorter or longer one, diameter is the best way for updates. If you replaced by both diameter and length, 1 family table may be better in the long run.
Ben Loosli
And if you were to go one step further and set up your parts as described in the Reuse Library whitepaper (which can be downloaded from the GTAC product download site) the dialog that is used will provide an even better presentation scheme for a situation like yours as well being able to include a diagram, similar to what you see in a parts catalog where the user will see exactly how the various parameters related to the size and shape of the item. To see what I mean, I've attached a screen shot showing a typical Reuse Library dialog.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Where exactly do I find the "Reuse Library whitepaper" ?
I'm on the full product download site, but not sure what the file name is.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I have used family parts and understand how the family table works, suppose I was just hoping for an easy fix that didn't involve putting over 350 variants in the spreadsheet.
Plus, as I said, I'm worried a family part of that size will cause problems (unexpected JETI exception) when I try to Publish it - far smaller sizes have done so in the past.
And there's another reason why Family Table parts might meet your needs better is because you can always go back into an assembly which has one of the Family Members added as a component and you can select it and ask that it be replaced with another Family Member which will be automatically created, swapped for the existing components and all of the Mating Conditions/Assembly Constraints will be maintained and the Parts List will update automatically.
And besides, which 'publish' a Family Table part, in your case, it will be as if you published all 350 variations since that one single part file has the potential to manifest itself as any or all of those 350 variations if needed by whomever you are 'publishing' this file for.
John R. Baker, P.E.
Industry Sector
Cypress, CA
