Water Tank Leak Repair
Hi All
In water reservoir, we found damp spot and water leak through crack. Would like to know form others who deal with crack-leak in reservoir. I am bit surprised when i found leak, because tank XYPEX- water proofing inside.
Water leak through shrinkage crack within15 days after poured.
Thanks for your time and input -
RE: Water Tank Leak Repair
1) Wait. Sometimes shrinkage cracks close up in a water filled structure as the concrete hydrates.
2) Inject epoxy in the crack.
I don't put a lot of stock in Xypex (or any other magic potion). It densifies the outer layer of concrete, but if the concrete cracks, it's still going to leak.
Thanks for your reply. I agreed too. some spot water leak through Shrinkage cracks,which wont stop by time.
Any suggestion for products for epoxy injection.
http://
http:
Make sure the product that you select is NSF 61 approved.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
