Transmission Line Paramter testing set
Hi All,
Can someone suggest a test set for measuring transmission line (132 KV, 200 KV, etc) paramters? Parameters include R, L, C, sequence impedances, etc. It is required to be used after erection of transmission line.
BR
Haide,
BR
Haide,
RE: Transmission Line Paramter testing set
I remember seeing one compact device for the purpose while doing google research some time ago. Now after many many tries, i could not come across it. Its sort of lost. Most the results from Google search brings up a similar equipment used for communication lines. I need one for Power Transmission lines HV and EHV.
BR,
Haide
