continuous loop pulley
I need a loop pulley system like what you might see in a set of blinds to provide a lifting force, except it needs to be able to lift about 100 lbs. Specifically, it needs to be able to use a rope (I've seen mechanisms like this using a chain, but that is too heavy for what I need. I'm pretty sure there's something out there like that, but I can't find it. Can anyone help?
RE: continuous loop pulley
@ Compositepro - LOL!
Adriaan.
I am an Engineer/part time student (Mechatronics) from South Africa.
Advice from lecturer: "Be warned - when you go into industry your boss will give you a thousand things to do and he wants them done yesterday!" So far he is right...
Enlarge the picture of the Brutus Hauler.
http://www.go2marine.com/product.do?no=99481F
