Plain text heading in the task column?
How do you insert a non-functional, plain text heading in the task column?
RE: Plain text heading in the task column?
IRstuff: The minute I enter any text in the task column, MSProject includes duration, start and finish dates thus considering it a task. I just want to have a plain text heading with no dates.
The question was:
What kind of an answer to that is "NO"?
Well then that's dissappointing because headings are really handy - they make it easier to identify blocks of tasks. Maybe someone will find a way to do it.
Oh good! Now I'll have to see if summary task structures does what I want. Thanks.
Yes, you may create your own headings in a task column. Each 'field' has a 'title'.  When you insert a column (or edit a column) you may add or edit the column's "title".  The "title" is what appears in the heading of the column.
Hope this helps you!
Dora
Learn the Secret Strategies to Quickly Create and Manage Project Schedules at http://www.CreateAndManageSchedules.com
