GE MATERIAL SPEC
4
GE MATERIAL SPEC
GE MATERIAL SPEC
LOOKING FOR A COVERSION OF A GE MATERIAL SPEC C50TF80
RE: GE MATERIAL SPEC
Don't use capitals- its like shouting
And it is difficult to read.
rmw
C50TF80 sounds like an EMPIS number.  This is GE's in-house numbering system designed to confuse customers into buying replacement parts only from GE (I know this because I once worked for GE).
I would google the terms 'C50TF80' and 'EMPIS' to try and find it - it is probably something very mundane (and available elsewhere).  Otherwise, any current GE employees out there with access to the secret code?
C50TF80 is centrifugal castings from iron base alloy M152.
