Sharpen display setting 5 as defualt? ST2
Everytime I open or start a new file the display sharpness
default is always set at 2... Can a change the default to
make it alway 5 ???
RE: Sharpen display setting 5 as defualt? ST2
Unless you're only dealing with small simple models you probably don't want to do that, it makes a massive hit on performance.
If you just want to get rid of the 'polygons' then '3' is adequate most of the time.
I'm afraid I'm not sure how to change the default.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
