CAM or license issue
Dear John or any other specialist,
May I ask you to help me in the following issue?
The customer does not see the CAM Session Configuration part of the Machining Environment dialog box when he switches into the Manufacturing environment.
This means that the Browse... buttons are inactive on the Configuration tab in the Manufacturing preferences dialog box.
So, when he selects the Fixed_Contour subtype of the mill_contour Operation type than he can only use five Methods from the Drive Methods on the Fixed Contour dialog box.
My question is that which increment(s) does cause the limited selection and which increment(s) must  we put into the license file for the fully functionality?
See the attached file.
As you see I logged this as IR1808416 to GTAC but I do not get any answer for this day.
