Ontario Building Code - definition of pitched roof
Hi all,Can someone please tell me the angular limit between a flat and pitched roof as defined by the OBC, or maybe the National Building Code?I'm told that in the US it is up to and including 5 degrees. Is it the same in Ontario?Thanks.
RE: Ontario Building Code - definition of pitched roof
If it is a structural issue you are referring to, there would be virtually no difference between a roof of say ... 2 degrees, 5 degrees, or 10 degrees.
