a simple question: the reference of a cell
I am not very good with excel... Looking for a command that would search for a given value in a column and return a reference (in a form C32 for. eg.) of the cell that value is in.
How can i do that?
RE: a simple question: the reference of a cell
Let's say you wanted to find the address in column D which contains the value 3. Use:
=ADDRESS(MATCH(3,D:D)+1,4)
(2B)+(2B)'  ?
Or perhaps a little more legible, don't use 4 for column argument.  Use
=ADDRESS(MATCH(3,D:D)+1,COLUMN(D:D))
(2B)+(2B)'  ?
Whoops. The +1 was not required.
Final answer (to find address containing "3" within column D:
=ADDRESS(MATCH(3,D:D),COLUMN(D:D))
(2B)+(2B)'  ?
My problem is that it returns the reference in form $D$15 when I need it only D15. Is there any cure?
Ok I found it.
But now why this does not work:
If:
=ADDRESS(Match(32,A:A),1,4,TRUE)
returns the 'A13'
and
=Offset(A13,1,0,1,1)
returns the value of the cell A14,
why does
=Offset(ADDRESS(Match(32,A:A),1,4,TRUE),1,0,1,1)
does not return the value of the cell A14???
Try this:
=OFFSET(INDIRECT(ADDRESS(MATCH(32,A:A),1,4,TRUE)),1,0,1,1)
(2B)+(2B)'  ?
Great! Thanx!!!
i've usually dumbed this down so that i have the maximum of the range in one cell then use another column to compare the maximum to the current row value ... if current row = maximum then cell = maximum (or 1 or "!!") else "  "
