welding of unlisted material
I have to weld a CS pipe A 106 GrB to transition fitting (IS grade).the material for transition fitting is unlisted in ASME code.
I have to develope a weld procedure for the same.
How i can do that? does ASME secIX allow that?
RE: welding of unlisted material
