Rosemount Transmitter water intrusion
Hello I have a Rosemount transmitter used for flow (0-250" H2O). It is getting water inside of the 4-20mA module side only. It gets about a teaspoon/tablespoon of water in it. Eventually it shorts/corrodes the module and I have to replace it. I have tried absolutely everything! I have replaced the transmitter, sealed it completely with and without the conduit/flex sealed. Placed a housing over the top. Covered it with insulating fabric and duct tape... We have redundant units only one transmitter does this. Any suggestions would be great! Thanks in advance!
RE: Rosemount Transmitter water intrusion
What stream are you measuring?
What quantity are you measuring?
What is the range, and units?
What model transmitter?
Is there a water source outside the measured stream?
Mike Halloran
Pembroke Pines, FL, USA
Try drilling a hole to let the water out.
Bill
"Why not the best?"
Jimmy Carter
Bill - My next step was to drill a seep hole, BUT my inquiring mind wants to know a cause for the water intrusion. Condensation is the only thing I can think of and that still doesn't seem to make sense because it is a lot of condensation in a little area.
Thanks for the info.
Bill
"Why not the best?"
Jimmy Carter
Mike Halloran
Mike - I am with you and it is indeed sealed. This one is a true stumper!
Thanks for the feedback.
My operating hypothesis here is that some stranded wire includes anti-wicking treatment, and some does not, and you got some that wicks, and it has a water source somewhere.
Mike Halloran
Thealanator - No and no. The conduit comes up, I have even went as far as disconnecting and pointing the flex down to eliminate theory of the underground conduit filling with water.
