Out of plane revolution axis?
I am really surprised Pro/E is letting me down with a feature I am trying to model.  I need to create a plane that is the revolution of another plane around an axis.  The problem is that the axis is not on the plane.
Is there anyway to revolve a feature, be it a sketch or a plane, around an axis that is not within the plane of the feature?  This seems like a pretty simple thing to do, and many other CAD packages support doing this simply with their revolve commands.
Let me know if anyone has had any luck with this.
-AAFuni
RE: Out of plane revolution axis?
Ok, sorry for the post, I solved my own problem.  It wasn't even that hard.  You can just pattern the feature around an axis, even an out of plane axis.
