Advise required for Sound Meter Use
I've been tasked with investigating the noise levels in my workplace.
This task has never been carried out and I have no experience of using sound measuring equipment.
The workplace is a foundry and fettling shop based in the UK, so as you may imagine it can get very noisy.
I have read the HSE website data regarding noise limits but I need some advise on what type of equipment I should be looking to purchase.
Am I currently looking at a Class 2 meter, frequency rating A & C. What else should I be looking for in a meter? (This meter will only be used once in a while so I do not want to be spending a lot of money on it)
Where do I have to position the meter when I am using it? How far away from the noise source?
How long do I need to use the meter for? E.g. If someone is using an air hammer/chisel for ten minutes every hour and then using other hand tools for the other 50 minutes do I just take readings for 1 hour then times by 8 for the rest of the day?
Thank you in advance.
Any help or advice would be greatly appreciated.
RE: Advise required for Sound Meter Use
http://www.bksv.com/library/primers.aspx
Ted
An audio dosimeter worn by a worker can record his/her daily exposure to fluctuating sound levels at a stationary position or if worker moves from one work place to another. If this situation is prevalent, then purchase or rent at least one dosimeter with PC software.
Walt
In the case of a fettling shop where impulsive noise is common I think you will get more value from a dosimeter than an SLM, and I think it needs to have the relevant time constant.
Cheers
Greg Locock
I have to imagine that seeing if there are companies that do this will be more cost effective that trying to buy a meter, learn to use it and potentially do the wrong thing, especially if your jurisdiction has a lot of health & safety laws.
TTFN
I have recommended to my boss that we seek professional help and have an independant company come in to carry out a noise survey for us.
Back in the 1980's I was a student working on a placement with the environmental NVH department of a large multi-national. We did noise surveys of factories and advised them how to comply with (company) standards and protect their employees. I never once saw anything connecting the company standards or indeed measurement practices to anything official. The numbers we used were always lower than the legal ones (typically -5dB), but I now wonder how legal it all was.
I suspect that any noise induced hearing loss (NIHL) court case would shake every possible branch to see what might fall.
- Steve
http:/
However, I would do the course, then follow the advice above (i.e. get a professional in to it first time and see how they do it).
M
Dr Michael F Platten
