welding consumable
welding consumable
I have to weld A182 F55 material by GTAW+SMAW process ,which welding consumables i should use??????
Also suggest welding consumables to weld A 995 Gr 4A material also.
I quick reply is highly appreciated
RE: welding consumable
No preheat
The root pass should be shielded with argon
EWTh-2 truncated conical tip
Interpass temperature 300° F limits of max, but the spec did not require it.
22Cr-5Ni-Mo-N composition. From A995 specification;
-Repairs shall be made using procedures and welders
qualified under Practice A 488/A 488M.
-The composition of the deposited weld metal may
be similar to that of the casting or may be suitably alloyed
to achieve the desired corrosion resistance and mechanical
properties.
Filler metals should be
SFA 5.9 ER2553 GTAW
SFA 5.4 E2553-XX SMAW
SFA 5.9 ER2209 (GTAW)
SFA 5.4 E2209-15 or -16 (SMAW)
If there are corrosion tests to be done alongside the basic weld procedure, you may find that these will help.
