Stellite on Carbon Steel - weld thickness
We are looking for a non-destructive method to determine the thickness of a stellite weld overlay on tubing. Does anyone have any experience with this?
RE: Stellite on Carbon Steel - weld thickness
Is the material in the as welded condition or has it been machined?
If the tube diameter is known why not a physical measurement?
Overlay has been welded. We thought about diameter measurements, but the tube diameter won't always be accurately known.
Did you investigate ultrasonic testing techniques?
I don't know how thick the stellite is, I would recommend using a Mil Tester.
Petrotrim Services
