Molded Foam Parts?
Molded Foam Parts?
Molded Foam Parts?
I am trying to start a fishing lure business and need help with material selection and machinery.
The body of the lure requires a molded soft closed cell foam.
RE: Molded Foam Parts?
Most soft fishing lures are made from flexible PVC. This can be foamed but I'm not aware of foamed lures as most lures must sink.
I am trying to make top water lures and they need a density of .35g/cc to function.
Try contacting Michael Reedy at Reedy International. He's an expert in polymer foaming.
Chris
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
It would be better to mold-in hollow cavities to lower density. Foam has much lower durability than solid. Hollow flexible PVC parts can be roto- or slush molded.
You could check out vinyl dipped foam.  Think floating keychain for boaters.
You can also check out polyurethane integral skinned molding.  It's not something you would want to get into doing yourself, at least not right away. (expense, epa regs, etc)  You could also look at expanded polystyrene bead molding.  This can easily be done at the hobby level with a modest investment.
I couldn't tell you what the densities of these materials are right off hand, but I'm sure google can help out in that regard.
Compositepro's suggestion of foamed plastisol (pvc) would also be a good one to check out.
Good Luck.
The problem I am running into is mixing and metering such small amounts that no company does it.
I have sent emails to over 30 companies and none can do it.
I have many suggestion for materials but nobody will quote making them.
