air flow metering
air flow metering
what is the more practical ways of measuring air flow in ducts and at diffuser outlets
please let us have your oppinion?
RE: air flow metering
2. Standard flows in duct is best with a pitot traverse. How to measure flow http://www.dwyer-inst.com/Products/AirMeas.cfm
3. Grilles are measured with a flow hood. Such as h
4. Smacna has an excellent testing and balance publication. http:/
See Alnor for balometers
B.E.
Flow hood is the only good way for diffusers.
www.ellisconsultingengineers.com
They usually list in around 5% accuracy and are not as directional as a pitot. Gut feeling is that the hot RTD resistance measurement would be more robust than a low static dp, and thus more likely to be accurate between trips to the lab.
Quality means a lot with instruments though. You gets what you pays for.
