ASME VIII Div 2- ? 1 + ?2 + ?3 ? 4S
Gentlemen - can you help explain ASME Section VIII, Div. 2 Section 5.3.2 required of σ 1 + σ2 + σ3  ≤ 4S.
I have a Square nozzle with rounded corners on a vessel that has been evaluated using finite element methods(NASTRAN).  Maximum stresses occur in a few elements at the radius corners in the shell.
All Pm,Pl + Pb, and Pl+Pb+Q  limits have been satisfied.
When performing the σ 1 + σ2 + σ3  ≤ 4S check do I use only the primary stresses (Pl and Pb) to calculate each of the 3 direction principle stresses or do I used the primary + secondary stresses (pl + Pb + Q) for this check.?.
Thanks in advance for any help you can provide"
Paul
RE: ASME VIII Div 2- ? 1 + ?2 + ?3 ? 4S
Paragraph 5.3.2 is very clear that you are to use the "local primary membrane plus bending principal stresses".  That means Pl+Pb.
