Out-of-plane Seismic force on walls
In determining the out-of-plane seismic reaction to the diaphragm, do you consider the inertial wall force due to
A:  the full height of the wall
B:  the height tributary to the diaphragm.
For simplicity consider a single story structure.
I've seen it calculated both ways with the latter being based on a lumped mass model.
RE: Out-of-plane Seismic force on walls
I think it should be based on the height tributary to the diaphragm if there is a attachment that can transfer force at the base.
C. Cantilever reaction
A & C if we are talking about the design of the anchorage of wall itself.
C. Assuming there is a parapet?
I have seen engineers not increase the load to the diaphragm when there is a parapet condition.  They have used the tributary area of the wall to the diaphragm, not the cantilever reaction, as they should.  Reading the OP again are you talking about out-of-plane reaction or including wall weight in seismic calculations?
