Standard for leakage testing automatic on-off valve
3
For automatic on-off valve(ball valve), should I test seat leakage according to standard ANSI FCI 70-2(similar with Globe control valve) or API-598 (similar to all type manual valves)
RE: Standard for leakage testing automatic on-off valve
For on-off ball valves, use ASME B16.34 or API-598.  Only case I can think of for using FCI 70-2 (control valves) is if you happen to have a metal seated, characterized insert or other specialty ball valve that is designed to be used as a control valve.
Valve should be tested by API-598 as it is a block valve.
I agree with bcd and bj45.  FCI 70-2 publishes leakage rate classifications because control valves are expected to leak.  On/off isolation valves are expected not to leak.
The leakage rate for metal seated ball valves within API STD 598 is similar to ANSI/FCI 70-2.  API 598 requires zero bubbles per minute seat leakage for resilient seated isolation valves.  Some manufacturers of triple offset butterfly valves offer the resilient seated specifications.
    For more details about the issue in object, You may want to take a look at the following threads within this Forum:
        -    thread408-265522: Valve Seat Leakages - FCI 70-2 Class;
        -    thread408-260420: BS EN ISO 1266 Leakage rate A vs. rate B;
        -    thread408-216962: Manual Valve Testing Plan;
        -    thread408-210466: What is 'Bubble Tight Shutoff' ?;
        -    thread408-172347: Drip drip drip;
        -    thread408-150132: "Zero Leakage" conept and EN 1779 std...;
        -    thread408-139863: Seat leakage classes;
        -    thread408-122060: ANSI/FCI 70-2 Control Valve Leakage;
        -    thread408-76110: FCI 70-2-2003;
        -    thread408-23297: Codes and Standards for leak testing valves...
Hope this helps,     'NGL
___________________________________
