NX5 - Reattached and/or Reposition - HOLE
I have a hole on a surface, positioned Point on to point (concentric) with oher hole. I deleted the old position parameter and I want to reposition it again. I can not pick the TOOL Edge at all !!! What is the trik here ?
RE: NX5 - Reattached and/or Reposition - HOLE
new hole pre nx5 hole?
It is a pre NX5 hole !
Somewhere I lost an associativity, I believe.
Any feture an want to edit, blow the whoole model.
I am in process of hunting all the features but one hole can not be repositioned (or I can not update it)
edit feature position add new dimension, choose dim type,
select an edge use for the second the face option an pic the hole face...
hope it helps
