FEM of Tension Buckling
Hi all,
I´m new here so I´d like to thank the creators of this nice forum and anyone who could help. Also sorry if i post this topic in the wrong place.
I´ll explain my issue.
I have a thin wall cylinder made of a long fibre reinforced material. The fibres are wound at a certain angle θ to the cylinder main axis, but they are NOT symmetrical (that is: they only wind at angle θ, not -θ too).
Doing a mechanical tension test, I observe buckling. This is strange, but logical. Infact, the fibre reinforced material is highly anisotropic, and a tension in the main axis direction (z) causes a noticeable shear in the zθ plane. In turn, constrained shearing causes buckling.
Now, I would like to simulate this in finite element code ABAQUS (6.9 version). I use an anisotropic material model, assign cylindrical material orientation, assign reasonable constraints (cylinder ends must stay plane) and apply a default axial tensional load.
After simulation, the buckling analysis just recovers the usual compression buckling modes (that is I get negative eigenvalues), but nothing else.
I thought it was an ABAQUS limitation, so to test this assumption I tried simulating the tension buckling of a plate with same material properties and constraints.
This time ABAQUS could recover positive eigenvalues (that is related to tension).
So I must imagine that I do something wrong with the modelling of the cylindrical case.... Any idea what????
Thanks in advance
Lorenzo
RE: FEM of Tension Buckling
You can also try performing a postbuckling analysis (Riks method), and put some geometric or loading imperfections to trigger the buckling mode(s).
Nagi Elabbasi
Veryst Engineering
