Erosion/corrosion rate
I'm preparing for a meeting where we are reviewing a piping system including steam and condensate piping.
All carbon steel pipes have an corrosion/erosion allowance of 1 mm. I would like to evaluate if this assumption is reasonable.
Do you know of any reference (hopefully a standard) that I could use to to evaluate the rate of corrosion/erosion?
RE: Erosion/corrosion rate
Corrosion and erosion are two different mechanisms that you have to evaluate separately even if there is the possibility of simultaneous erosion-corrosion. you've to define the type of corrosion based on fluid composition and operating conditions (CO2, water??) and the you can assess the likelihood of erosion using for example the API RP 14 E or the DNV RP O501
http://exchange.dnv.com/OGPI/OffshorePubs/Members/rp-o501.pdf
http://www.gewater.com/handbook/index.jsp
hope this help
S
Corrosion & Rust Prevention Control
Your piping has a minimum Cr requirement right?
There have been a number of EPRI reports on FAC (flow accelerated corrosion) of steel in wet steam service.
These would be available from www.epri.com
Plymouth Tube
