Character " in a string expression?
Is it possible to add the " character into a string expression in NX6?
RE: Character " in a string expression?
Can you show the expression that you are trying to do?
PIPE, WELDED 2" SCH40S
I found a workaround by using '' instead of " but I'm not satisfied with that result...
Daluigi,
I think this may work for you.
"PIPE,WELDED 2" + CHAR(39) + " SCH40S"
HTH,
 Joe
It's actually CHAR(34).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Lovely! Thank you
Is there a list of what CHAR(###) are available for NX7?
I've been frustrated by that too.  It seems that the developers were a bit lazy and let the database structure out into the wild of the user expeirience.
Why would anyone ever use the double quotes in a notion field of an engineering software?
NX 7.5.0.32 MoldWizard
We had to use SOMETHING to delimit what constitutes an actual "TEXT STRING".
John R. Baker, P.E.
Industry Sector
Cypress, CA
