red dimension on solidworks
drawing dimensions became RED. I would like to bring them back black ...does anyone know how?
Thank you
Thank you
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: red dimension on solidworks
It's an over-defined dimension.
http:/
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
If you're sure that nothing is over-defined, see if you have your dims on different layers...assuming you're using layers.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Are any of the dimensions controlled by a Design table?
Try toggling the Color Display Mode icon in the Line Format toolbar.
I even verified colors in :
Options> Colors> Color Scheme Settings>Annotations> Edit.
and everything seems to be fine.
The only way i can remove the red and blue dimension is by erasing the dimension and add it back. I have a lot of drawings and I can't do it to all of them
Can you ZIP and post a simple example here?
What graphics card and driver?
Go to options:
Options> Colors> Color Scheme Settings>Dimensions> Edit.
Check all the dimension color settings, there's about 5 to review
Dimensions are separate color options than Annotations
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
when I open a detached drawing and select dimensions to intersection points, the dimension end-points appear red until the model is loaded, then they are fine
