Design Moment Versus Maximum Moment
Can anyone tell me the difference between the Design Moments (Top/Bottom) and the Maximum/Minimum Moments.
When looking at the analysis results tables I realized that the maximum/minimum moments (from the strip forces table) is about 35%-50% less than the design moments (from the flexural and shear data table).  Both are strip based and correspond to the same load combination.  I thought maybe the strip forces table was using service loads but that is not the case.  Thanks for your help.
Thank you!
Lisette
P.S. I am using SAFE version 12.3.0 and am designing a two-way slab with design strips in both directions.
RE: Design Moment Versus Maximum Moment
The design moments are probably taking into account the twisting moment Mxy, by adding it in with the wood-armer method.
thank you handex!  that is the exact answer we just figured out over here.
