Do Solar Panels make a Heated Roof Unheated?
Curious how you guys have been handling this. I am running into situations where I am being asked to review existing buildings for an additional dead load from solar panels attached to the standing seam roof by S-5 clips and a rail system. In some cases the building was considered heated for the original design. When solar panels are installed and they cover a significant amount of the roof I have been considering the roof to be unheated since the panels are usually off the roof by 6" or more. On the other hand I have been told that photovoltaic panels generate heat when in operation. Is it too conservative to consider the roof unheated? Is there any standard which addresses this condition?
RE: Do Solar Panels make a Heated Roof Unheated?
Look at ASCE 7-05 Table 7-3 (p.93) for an explanation of the Ct factor.
I am no expert on solar panels so take this with a grain of salt but I have been told that they can operate with quite a bit of snow on them. However, their efficiency is greatly reduced. This probably varies from manufacturer to manufacturer and between models.
Just a thought.
