ASME rupture disc
ASME rupture disc
Dear ALL,
I'm in troubles, can somme one help.
I didn't find any bidirectionnal rupture disc for Sanitary application witch comply with ASME code Sect. VIII div.1,the burst rating is +18 psisg/-3 psig.
my coonection is 2in dia.Try clamp.
do you have any other solution to protect my vessel for pressure and vacuum.
THANKS.
Laurent.
THANKS.
Laurent.
RE: ASME rupture disc
SO now I'm looking for ASME Vacuum breaker.
If you have any other idea, please let me know.
thanks.
LAURENT
Please check with manufacurers of rupture discs offering bi-directional sanitary rupture disc such as the Lo-V from Fike (see http://www.fike.com/products/rdlov.asp)
BR
Roger
Uufortunatly this Fike sanitary rupture disc do not comply with ASME code, i can't install it on coded vessel.
I'm still in troubles.
LAURENT.
I am not aware of any bi-directional discs on the market that are ASME certified. Additionally, I don't think there are any sanitary rupture discs that go down to 3 psig that are also ASME certified. I really do think your only option here is to use an ASME certified vacuum breaker in conjunction with a sanitary rupture disk like an Axius SC on the website mentioned above. If you find another solution I would love to hear about it. Good luck!
