Surface Roughness Ra 3.2um
3
What is the tolerance for a Surface Roughness Ra 3.2um. Is it 3.2 ± the general tolerance on the print. Or is 3.2 the max reading as in 0 - 3.2
RE: Surface Roughness Ra 3.2um
Surface roughness is a maximum, meaning Ra 3.2 micrometers maximum.
My readings range from .97 - 1.02. is this "too smooth" from the 3.2 callout
There is no lower limit callout. Thank you KENAT
