MathCad - Formule interprete
in the attachment you see what my problem is. I've got a formula and it calculated something to the power of 1.667. But instead if taking units to the power it should only take the number to the power of.
Hoe do I have to change this that it only takes the number to the power of ... and not include the units.
Daniel Schonfeld
Daniel Schonfeld
RE: MathCad - Formule interprete
Empirical formulas and the like are annoying that way. You need to divide out the units first, and then add in the units afterwards.
One benefit of correctly normalizing the units in an empirical formula is that it will then be applicable to other unit systems as well.
TTFN
