Question about laterally loaded piles
Hello Engineers,
I have been working on secant pile drilled shaft project and now i'm at the lateral analysis design stage, using LPILE.
As you may know, LPILE allows you to enter a section and compare its maximun bending moment with the maximum moment you get from your soil profile.
In order to compare both values, I was told I need to amplify my maximum moment I get from my soil profile by a factor of 1.75. I am not sure if this factor varies between project (e.g Secant pile wall, or deep foundation). I just would like to know where can i get more information about this amplification factor.
If anyone knows, please let me know.
RE: Question about laterally loaded piles
I'm only guessing hear, but I expect that the factor is a structural design load factor.
ACI 318 has a load factor of 1.6 for soil and a phi factor of 0.9 on bending. Combining the two gives a 1.77 factor which is close to the 1.75 you were told to use. That is my guess as to where the 1.75 comes from, but ask the person who told you to use it, hopefully they know
That 1.75 came from some chapter in the LFRD code.
It makes more sense to me to use ACI 318, by amplifying the maximum bending moment by 1.6 and comparing this one to the max moment I get from the pile section using a reduction factor phi (0.9).
If not, ACI should have factors for moment magnification to be applied.
I am not sure if there is an option in which you can enter the factors.
I have not used LPile, if it doesn't do a non-linear analysis of the pile structural components, the input should be looked over by the structural engineer to see if it satisfies the structural considerations of the deep foundation. One of the structural issues I am thinking about is P-Delta effects.
http://www.jmst.org.tw/marine/12-1/62-70.pdf
